Below is a screen shot of a split clamp block I'm making. I'm using the bore as my X and Y 0,0 reference. Top of the block is my Z 0 reference. My mill cuts the outside profile as it should and I can chamfer the profile with no problems. Using the same X, Y and Z references to chamfer the bore the cut is not on center. I've double checked to make sure I haven't lost steps between operations, which I haven't. Set up the gcode files to cut both the profile and bore chamfer cuts as one operation and separated them into two operations. No difference, still wants to chamfer the bore off center. Not sure what is going on. Anyone have any thoughts on this?
For info I'm running Mach3 version 066 and D2NC for my CAM software.
Tom S.
Tom S.
