- Dec 19, 2012
- 38
I'm thinking these will be OK after some more work, I'm using the Millrite as my press and some v-blocks. This particular kit puts the Y axis motor out the back of the column, it will stick out straight unless I make a plate to mount it on the side and use belt drive. I like the idea of no motor sticking out the front. This kit also reuses most of the bearings for the screw supports, I have read that back lash can still be an issue so I will see how that goes once I get it assembled.
I haven't decided on software to run it yet, probably should stick with Mach to start. I went with this machine because there is so much info out there I figured I wouldn't have to reinvent the wheel, lol
I'm not the most computer savy so I will have questions around that. I'll take pictures as I go, if anything its a great reference to look back on if something just doesn't seem right!
I appreciate all the helpful comments.
Mark
Mark
