Let me try to save you some time and money. I advise you to sit down and do some homework.
- DEFINE for yourself what your needs are. This, more than anything else, determines the size lathe you need. You've already been told to buy the biggest lathe you can find/afford but this does not fit all of us. You are the one who will live with this lathe so focus on your own needs.
- KNOW which features matter on a good lathe and know why they matter. It may take some time to research why a camlock spindle is better than a threaded or bolt-on spindle, or why a separate drive shaft to move the saddle is better than a key running in the slot of a leadscrew but these kinds of things determine how easy it is to live with the lathe and can impact on the lifespan of that lathe. You cannot add these features after the fact so figure this out before you spend money.
- Fully featured lathes with all the good stuff (quick change gear box, cross slide power feed, separate drive shafts with a clutch, etc) are found on 12" lathes and bigger. Hobby class lathes often lack some of these features, tend to be cheaper and the quality of the machine is usually lower. This is not a uniform thing. Some European small lathes are made to tool room standards so you need to do your homework.
- The tooling used (carbide or HSS) really depends on how much speed you can get and the rigidity of the lathe. In order to fully use the capabilities of carbide you need speed, power and rigidity. Take a 3/8" SCLCR turning tool and use it on a 10" lathe on small work and you get a result but use that same tool on a big 14" lathe on a larger work piece and the results are often much different. This has to do with getting the work to the right speed for the tool, then applying enough power and rigidity so the tool can cut as intended. When using carbide tools, the speed the lathe can run at matters and this ties in to the size of the work piece. So again, what do you intend to do with the lathe.
- You intend to CNC the lathe; your call, but there is soooo much about lathe work that you have to know in order to really program a lathe to do what you want. Plan to spend a lot of time learning to use the lathe first so that you understand how this machine cuts metal or you will have a heck of a time running it as a CNC machine.
My point: figure out what you need, then find the machine that has the features you need or want. Believe it or not, upgrading lathes is not the best way to save money.
