From the Smithy website:
https://smithy.com/product-support/maintenanceGrease Points
"In addition to oiling your machine, some Smithy's are equipped with grease fittings and you should plan to grease these points at least once a month. In our shop we use, a general automotive and industrial multi-purpose grease from Valvoline.
You should also coat the gear train gears with a light layer of Multi-Purpose Moly Grease. If you have a Granite machine or CZ-239, keep the quick change gear box lubricated with Moly & Graphite Chain and Cable Lube. The wand allows you to access the gears easily and chain lube tends to be "stickier" and better penetrating."
Hope it helps.
Tom
