Hello everyone!
I started another thread here to solicit help on choosing my first mill. I think I've found one and now I need to figure out how to move it. The mill I am looking at is either a Lagun FT-1S or FT-2 ser # 19846. I need to get with Lagun tomorrow w/ the correct serial number for confirmation of what this mill is. Lagun seemed to think it was a FT-2 from the pics. Regardless, I believe this mill clocks in at >2000 lbs. Seller is asking $3500 and with a few small exceptions, the machine seems to be in good shape overall, but hasn't been used in several years so is pretty dirty. Now, onto moving it...
Some pertinent information:
I have never done anything like this before... could a couple of guys "push" the top of the mill to tilt it slightly to get pipe under it or does something need to lift it off the ground to get the pipe under it? If I have to lift it anyway, might as well go the route of the palate, no? If I go the route of the palate, can the mill stay on that permanently to allow me to move it easier in the future if needed? Hopefully these questions demonstrate how badly I need advice here.
Thanks,
- Joe
- It is located approx 40 mins away from me in the seller's detached home work shop.
- The mill is sitting directly on a concrete floor (not on a palate or anything like that)
- The seller has a large front end loader that can be used to lift the mill onto a trailer, but the front end loader won't fit in the workshop to pick the mill up. The doors to the workshop are 12' x 12', but the front end loader is bigger than that.
- The seller has several palate jacks that can be used to move it around inside the workshop if necessary
- The mill has what looks to be a factory lifting eye/hook
- I have a 1500 class pickup truck and was planning to rent a drop trailer and a palate jack for transportation home. Might be able to talk the seller into letting me borrow one of his palate jacks.
- The mill is going into my home workshop (2 car attached garage) at the top of a slightly sloped, textured concrete driveway
- I have a friend that was a mover in a previous life and has moved heavy things, but never a mill. He offered to help with this.
- I have absolutely no experience doing this. I don't own any heavy lifting equipment.
- Lift up the mill - either onto a palate that I would need to build or onto gas pipe to roll it
- Get it outside the seller's workshop where the loader can pick it up and drop it onto a trailer
Thanks,
- Joe
