Burke No. 4 Vertical Attachment
I used the vertical head for making some t-nuts and ran into some space issues due to the offset of the vertical head with the table also length of end mill bit. A little challenging although was able to do what I needed. Keep in mind that this is my first use of a milling machine and as with anything else there is a learning curve and lesson learned was to do a little more planning per job setup such as moving through the planned sequence of cutting to make sure that I am not painting myself into a corner.
Harry
Already I've encountered the space issue thing. Maybe clamping things directly to the table will help, that's my next move.
