Cutting the notches in the hammer turned out to be a royal pain. Not because it was difficult work, but because I neglected to get the machining order straight before starting the part. With all of the different angles, it would have been much easier to machine the notches before milling the outline of the hammer. Then there would have been lots of straight and right angle surfaces to work off. The two angles of the full cock notch were cut and the half cock notch roughed out with and end mill, then the half cock notch was finished with a form ground fly cutter.
This was the setup used to cut all of the angles on the notches. Some of them were set with a sine bar and some with a protractor. This pic shows the form cutter ground to cut the deep half cock notch. The bluing (Magic Marker) serves as a witness to show when the cutter touches.
The finished hammer. Each of the eight different angles around the notches was a separate setup. :nuts:
This shows how the breech block, lever, connecting link and hammer all interact. In this pic, the lever is being cocked and the link is pushing the hammer to half cock. Once there, the link will pass the hammer allowing the lever to actuate the extractor, which is farther down on the task list. I think it only makes sense to make the trigger next.
