- Jan 25, 2015
- 2,558
Mounted the tach sensor for the rpm gauge today:
The magnet is a small neodymium dot. Hangs on to the spindle just fine all on it's own. Routed the wire through a rubber lined clamp to keep it out of the change gears and added a second clamp on the bottom of the guard for neatness if nothing else.
I used an old adapter (12v) from my junk drawer to power the tach. It turns on and off with the power bar, which turns everything else off too.
I popped the connector into the control/display head and powered it up.
Looked good, but I turned the lathe on and it stayed at "0". I did a bit of troubleshooting, but it wouldn't move off "0". I had a second head (bought for the drill press), so I plugged that in and it worked fine.
I turned them both over and inspected them with the 20X lighted magnifier. Yep, there it is: the first head is missing and OpAmp on the board. Looks like it was knocked off the PCB somehow, you can see where something used to be soldered to the pads. Shipping, birth defect or it happened on my shelf, I have no idea. It was also bought back in feb so any chance of returning it is long gone.
A stroll through ebay reveals it's as much for an op amp as it is for a new display since the chips had to be bought in quantities. Ditto for non eBay suppliers.
A quick rummage through the junk drawer again turned up a handful of opamps. Looking up the specs called for a Ic 8-16 mA OA on the pcb, but the closest I had was one spec'd for 50 mA. Well, it's just a diode and an emitter array, the display is useless like it is, so i figure what the heck: fire up the Weller wesd51 station and drop the 50 mA OA on the board. Do or die!
Out to the shop, plug it in and: bingo!
Works perfect.
So I'll put the "as delivered" one on the lathe and put the repaired one away for the drill press.
Quick vid of it up and running:
Seems to track fine and is plenty accurate for the type of work I'll be doing. Takes a second or two for it to refresh to zero once it stops, but that doesn't matter a wit to me since I'm done with working whatever is in the chuck at that point anyways. It will take longer for me to grab the mic and measure the work than for it to refresh to "0".
Decent bit of work for about an hour's worth of time. I'm quite happy with the results.
Works perfect.
