Building/modifying An Atlas Th42
Got my first practical use out of the lathe today. Used it to turn down a shoulder for the swingarm pivot on my VF750F. I'm grafting on a CBR600RR swingarm and the original pivot bolt had a step in it that prevented the bolt from going fully home.
line it up in the 4 jaw, a couple passes and it fits slick as snot now.
Next up: a spacer/sleeve for the other pivot bolt that will adapt the bolt to different sized bearings.
Pretty soon this old lathe will have paid for itself.
If I can stop buying things for it that is....lol.
Found a used axa wedge qctp on eBay.
Post (with t nut), two knurlers, cutoff holder with bit and one tool holder.
99 bucks.
Grabbed it right up!
Boring tool holder and maybe a couple extra tool holders and I'm set.
$$$$$ out the door! It is a terrible disease!
Pierre
Pierre
Surely is!
But for 99 bucks I couldn't beat the price anywhere. Even with the highway robbery PB shipping.
By the way, that was one heck of a packing job you did on the leadscrew!
I had to use the cut off saw to (carefully) open the PVC tube!
We ship some delicate stuff in lengths fairly often and this has been one of the best ways to do so. Enjoy.
Pierre
Found a shop out of UK that was selling chucks with 2 mt arbors.
40 bucks for a 6, 10, 13 and 16mm chuck.
"Diamond brand", a cheap Chinese built set for sure.
But, I need a tailstock chuck, the wallet is very thin right now and even a crappy piece of tooling is better than nothing at all. My use is infrequent and light so these should do fine, at least for the interim if nothing else.
First project off the "new" QCTP. I have troubles with small grips and my hands on my motorcycle. The only ones I could get had a big HD eagle and "V-Twin" on the end:
My bike is a Yamaha and a V4 so that won't do. I decided to spin up an nice little end cap to cover it:
A little recess for the "V-Twin" emblem to reside in:
And it slides right in:
A run over the polishing wheel and some steel epoxy and should be good to go.
Or I may drill and tap a small machine screw to hold it to the end cap on the grip. Haven't really decided yet.
QCTP worked great though. felt very solid.
Parting sucked, but I think that was more the user than the tool......
why not just raise the lower side on the cabinet? then you will have a place for extra chucks wrenches and other bits?
