I did a bit of looking on you tube. I saw a method for me. The cherry was lathe cut 20% smaller than finished diameter. Then set up like a boring bar on the toolpost. This was fed into a hole drilled into your blocks, which are mounted in your chuck/plate. You then bore it to your bullet size. You should have a look see. there are other methods too.
