- Oct 24, 2014
- 208
Brushed finish, or "graining" as we used to call it is done with enormous belt sanders and sometimes "Flap" wheels in a production environment. If it's absolutely flat, u might get away with a belt sander, but your fears are warranted. Part of my last job was restoring brushed stainless equipment, and practice and patience with a sanding pad seemed the only reliable method. The brush finish actually consists of short scratches 1/2 to 1 inch long among thousands of others. Difficult to reproduce in a shop because most methods produce long or continuous scratches. I had some success with a "drum" type sander in a cutoff type rotary tool, The drum needed to be slightly soft under the sandpaper tube or roll. U might get away with using the nose of the belt sander rather than the whole surface ...?.....Use of a fairly coarse emery paper seems best. 100 - 180 or so, but that was for stainless. good luck !
