Broken r8 collet nub (set screw) pm932m
  • Thread starter Thread starter umahunter
  • Start date Start date
I run without one too (Lagun). Makes changing tools quick and easy, especially if you use a Maxi torque or alike.
Mine sheared off, too. Never even noticed a difference, other than that it's easier to put a tool in.
Well I noticed part of my problem is the first couple threads of my drawbar are stripped never noticed it before it's been a lil tough since I got the mill I just thought it was cause it was a new mill and new collets not sure how it would strip unless it came that way I always tighten it by hand then give a turn with a wrench :(
R8 tools normally have quite a length of thread engaged. Threads can be easily damaged if someone loosens it almost all the way out, then hits the top end with a hammer to drive them out. I make a habit of loosening only about 1/8" before tapping it down. Also, I find that I don't have to tighten the drawbar very much to hold securely. Usually one hit with a plastic dead-blow hammer is enough.
If you have to make a new drawbar, pick up a piece of threaded rod that's a grade or two better than the hardware store variety. Cut to length and screw a nut on the end, then weld or pin the nut in place. Roll pins work for that.
