- Jul 6, 2018
- 23
Hello,
As you can see from the title the headstock has broken around the bushing mount. I was in the process of changing the bushings and if I ever find one the thrust bearing; ( if you know of any crossovers I'm all ears) while the tension piece said goodbye. I even used dry ice to shrink the brass.
My main question is it possible to replace the headstock cast from a newer year? The bed on this unit is the 30". My next question is would you weld it?
I mainly use it for small jobs related to my farm equipment and antique tractor parts. I really don't want to part it out as my grandfather bought this thing brand new back in the late 40s.
Thanks in advance,
Stefen
Thanks in advance,
Stefen
