Broach--max. Length Of Cut, Length Of Bushing
DuMont has some good information on their web site: http://dumont.com/resource-center/broaching-hints/ . They have some suggestions for WreckWreck's problem:
Suggestions for a drifting or “hogging” Push-Type Keyway Broach:
  1. Reverse workpiece or turn Broach so teeth face toward the back of the press.
  2. Let the Bushing protrude above the workpiece to give more support to the back of the Broach, thereby helping to keep it aligned. If a collared Bushing is used, place it upside down under the workpiece.
This page gives the force required for different broach sizes and materials: http://dumont.com/our-broaches/push-type-keyway-broaches/american-standard/
The forces escalate quickly. My 1/8 broach need about 720 lb for maximum LOC in mild steel, but up the width by 1/32 of an inch to 5/32, and the force required nearly doubles, to 1320 lb. And a 3/16 is 1860 lbs. ! Closing in on a ton on a steel bar 3/16 wide. Keep things aligned! The size C broach for 3/16 only takes 1540 lbs, as it has 22 teeth vs. the 16 on the B broach.
My jet #3 is rated 3 tons, but only has a 16:1 ratio at the end of the arm, requiring 375 lb on the end of the bar to develop 3 tons... That ratio says my broach should take about 45 pounds to push through, and that seems about right (like picking up my granddaughter).
