Greetings,
I have a BP round ram knee mill. (M head) In pretty good shape actually, that i got for $500. I had to replace drawbar, some felt wipers and the spindle oiler wick. It had been lubricated with GREASE it nearly all its fittings so the cleaning process took a long time.
Now, the table works well from right to left, (starting full right and moving left) BUT when it gets half way in this travel the table binds so tightly it takes two hands to turn the cranks. Anyone have an idea why this is happening?
1. Will a two piece cross feed nut solve this? ( If so, can I just cut the current single piece nut in two?)
2. The gib had a very thin piece of tin spot welded to it when I took table apart to clean and OIL. (like some sort of a shim)
3. Can new table gibs be purchased?
Anyway, I'd like to get this fixed so I can use the whole table. I have a BP vice bolted down in the middle but have to move it for bigger projects!
Thanks all info and comments in advance.
Dave SO FLA
