- Jan 31, 2016
- 12,859
There should be an adjusting screw for the spring tension also . I'm going off of memory here , but try the upper set screw , this may be that adjustment .Thank you, the spring isn’t strong enough at the mo. To support the tool in the cutting position, it has a little brewers droop!
