The hard part about a good tutorial post is remembering to update the thread with the changes you have to make once that original plan meets the enemy. After I had to switch up the Mesa board due to availability, I found out that the one I got didn't support 24V controls. Only 5V outputs, and one 0-10V PWM output, meant to control a VFD. That meant the original relays I had on hand wouldn't work. But, I found these:
So now the Power Box looks like this.
Power comes in via a 220V, 4-prong, lock plug. L1 and L2 pass through a 30A, DPST switch.
Inside, one leg goes from the switch over to the left-bottom to a bank of fuses. The other leg goes to the set of red DIN connectors at the bottom. Three are ganged together, to give me five branch points. The Neutral leg goes to the three gray connectors on the left, once again ganged. The ground is picked up by the green-yellow that is ganged with three gray. The kit only had one green-yellow for some reason.
Counting up. The first fuse feeds the two relays on the right side of the DIN rail. The relays are 5V controlled, and the wires for that come in through the DB15 connector on the left. They need to be powered by 5V from the Control Box, and then a 5V control signal. The relays control the outlets with the blue markings, which read coolant and lube. Which one does what is left as an exercise for the reader.
The second fuse up send power to the auxiliary outlets. One of these is taken already by the monitor. The other will most likely be some sort of work light.
The next three fuses got to each of the X, Y, Z stepper power supplies. I could have run these off 120V, but 220V reduces the current draw. The other leg is unfused, but breaking one leg breaks the circuit.
In the same way, the top fuse supplies one leg of 220V to the VFD. The VFD is controlled via 2-wire RS-485, coming in through the DB-15.
The stepper power supplies feed the Control Box via the cannon plug on the left. The VFD will control the motor via a gland on the top of the box. Barely visible on the bottom left is the filter for incoming air. Above the power cord is an externally mounted exhaust fan. I may need to add exhaust power, but the VFD and supplies all have fans, and they all are pushing air up. I'm hoping that with the chimney effect, it will be enough. But, I do have one of those later thermometers to test the temp gradients.
Next up will be the Control Box. I have it mostly done, but I still need to wire in the limit switches and the original power controls. I'm also still wondering if there is a way to connect a spindle encoder to a BP.
