Bridgeport fine feed wheel?????
Mine has the same knob, but does not retain the wheel. The wheel is made for easy removal.
Randy I have removed it and tried to fit it through the wheel 3 times just to make sure. Mine dont slide over it. It will slide up to about the knurl from either direction. Maybe we should add that to the list of things to buy, just to be sure it's the right parts I guess.
It has enough room to back the pin out so the wheel can free spin, but it wont pull off with out removing it.
I do not doubt you Chuck. I am sure there are machines that are made both ways. Thanks for your input.
I dont know if it was made this way or made to be this way. All the BP and clones at school the wheels just slide off. Heck I dont even know where any of them are. Maybe someone at some point made there own knurled end so the handle would stay on.
I did note 2 or more part numbers for this part though. So who knows
B'port ignorance on display here but what purpose is served by having the fine feed wheel be removable?
On my Gorton mills the fine feed wheel is bolted to the downfeed gearbox.
Is the wheel in the way of something on a B'port?
The easy removal of the fine feed wheel is just a convenience as it does sometimes get in the way. They probably first engineered it as none removeable and found they could easily make convenient to remove. Bear in mind this is all speculation on my part.
Grizzly has several nice options for making a replacement. They need work to complete them to fit your machine, but real cheap. I will have a cast one on my next order.
If you have one of those accessory z axis digital readouts attached to the head. And attached like the instructions say to do it. You have to remove that hand wheel! I’m still amazed that after all these years of poor design that no manufacture has fixed it so you can have the digital z readout and the handwheel too. And yes, my BP has the knurled reverse switch and the handwheel just slides on and off.
Gorton got it right 80 years ago.
I think the reason Bridgeport leaves there fine feed wheel with the remove ability. Is when using the power feed they don't knock you fingers into broken digits. Just my thoughts on them . I use to just pull them free of the pin hole and use the feed. But I can see some dingbat leaning hand and it catching on something.
