Bridgeport CNC with Masso Controller/Clearpath
This is going to be my first CNC build and my First build log. I've decided that a build log on this forum might be a good idea for this project so the next guy to take on this project doesn't have to deal with the stupid stuff I'm already running into.
This is my Masso Controller
I will be using 3 Clearpath Stepper Killer servos model# CPM-SDSK-3432S-RLN
They are a little over 6" long...
almost 3.5"
1/2" shaft with a 3/16" keyway
I will be using Teknic's IPC-5 75VDC power supply
But before you can wire up you Masso controller you have to power up the Clearpath servos and plug them in to a PC with the ClearPath USB-B cable and it absolutely has to be their cable I've already tried 5 others, now I'm waiting for UPS to deliver a "Teknic Certified" USB cable. Very Lame....
Their program will not see my servos without the "Teknic Certified" USB cable...
Edit: Almost any USB cable will work.... lol
Did some more test cuts on a large piece of bronze..... All this was done with the Masso's conversational programming feature.....It has some problems, the conversational programming make some strange moves stopping in quarters of a circle making high spots at the stops and it only does full diameter step over when milling......lol I'm still trying to figure out how to get Fusion 360 to work with my machine.....
I think I'm going to try to build a probe from garbage next....
That bicycle hub is another project that I just finished, It has 863 bronze bearings pressed in both ends with 863 bronze thrust washers, a 5/8" 1045 axle and a zerk fitting to fill it with grease.... :cool:
First somewhat successful file from fusion 360
Running at 2700rpm filmed in slowmo to see how big the chip was..... lol
I think I need to push the feed a little faster.... thats only 15" per min.... gonna try 30" per min on the facing cut next......
I just ran my first successful 4 step operation from Fusion 360.... The New 5axis Post processor file Masso just uploaded to Autodesk works great.....
Faced the part at about 30" per min and the rest of it was at about 10-15" per min..... Runtime was 42 minutes 33 seconds......
Milled everything with a 9/16 carbide end mill..... The boring was done in 2 steps the first was the smaller deep hole and then it did the larger shallow hole.....
Congratulations! Great job working through all of the issues. Looks like your servo on the Z-axis with the planetary gear reducer works great. I was wondering how that would work. I'm guessing you have no backlash because of the weight of the knee. Sure bumps up the travel as compared to doing the quill.
Bruce
Bruce
Thank you..... I actually have backlash on all 3 axis but the Masso controller has backlash compensation, that works perfectly...... The knee has the most backlash because of the play in gear teeth...
This project has been kicking my ass for almost 2 years now but it finally works!
I want to start my building my plasma cnc table soon, going to be 5x5' but the drive design is going to be modeled after this Italian company that makes cnc routers that make very fast movements.... I can't remember their name....
This website will help you figure out if your Gcode will work before you try it on the machine....... It helped me learn that I was putting my work origin on the bottom of the stock causing my knee to crash every time.... So for those who don't already know you need to make the work origin on the top of the part or stock to be cut in Fusion 360......lol:face slap:
