- Jun 23, 2011
- 786
Thanks for the input, guys.
I checked cal on the tach with my belt-drive drill press. According to the belt chart, it should be 540 RPM. Tach reads 510 +/- 2 RPM. About a 5% error--within expectation.
My tach has a bright red illuminator, and a red filter on the detector. This filters out most ambient light. It came wit some stick-on highly reflective strips, kind of like what highway signs have on them. To eliminate extraneous false reflections, I wrapped the spindle with black electrical tape and put the reflective pad on the tape. Readout on the head says 500, tach reads a pretty steady 960.
I also checked to make sure the dial on the head readout hadn't slipped. It hadn't--The speed adjust is turned all the way to its stop on the slow side, and the dial reads 500, just what it should.
Is it a PITA to pull the motor off? I'm guessing at this point you'll find it's running 2X as fast as it should for the reduction in your mill...
John
