Brass
image.jpg Should work the three smaller holes are there if I need to attach a plate to back instead of rotating mount. The corner holes are alignment dowell pins ,the two allens clamp the caseings ,
These are 30/06 it will work on any 30/06 based caseings., Ok tried it out x slide vice and fixture work good on mill, not so good on drill press kinda ruff cutting , going to try to rigitize drill press, any suggestions ?.
Thanks
Thanks , mabey I'm confused I thought of a slotting cutter as a small saw blade with an arbor thru it, is that a spline cutter / slot cutter ? , I have a bunch of them but all are thinner.
Or is there a different type cutter I haven't seen yet ?.
Thanks
Derrick
It is a saw mounted in a arbor. I mean a slotting saw, comes in different thickness. I think any over a 1/4 inch thick are milling cutters. In my experience they sing when they cut. I like your fixtures.
