B'Port clone rebuild begins
Thanks for the input folks. I think I'm gonna go with on the wall, not the corner. My issue is that I will be moving the base into place before I have the ram to put on it, so I need to try to get it in place with enough clearance to start with.
Just got back from vacation, so back to work.
Base/pedestal is done.
That's the aforementioned smoke grey Rustoleum oil based professional with just a bit of acetone to help it flow, and hardener from Tractor Supply added at a 1:8 ratio. The black is Rustoleum flat black, acetone and hardener at the same ratios.
Now to work on the knee and turret.
Lots of things taking my time away from the shop, back to get a little bit done. Got the knee pedestal painted. And the brass treaded insert cleaned up.
And I finished the filler work and painting on the knee.
Now I have to fix that broken gib for the knee. I'll update that thread to keep it together. Basically I have some silicon bronze rod, I'll use my tig welder to try to build up the end.
I've also come to the conclusion that I have to do some rearranging in the shop before I can do much more on the milling machine. I need to get my round column mill out of the room before I put the knee on the big mill, otherwise I wouldn't have room to get it out. And of course I have to find a spot to put the little mill, which means moving something else.....one step forward and 2 steps back.
"Well Woodrow, slow but sure."
-Gus McRea Lonesome Dove
Back at it again. I got the round column mill moved out and in a usable location for now. At some point it will go away to a new home, so moving would have to be done anyway. I also got the knee mounted on the base, and the gib in.
But I have a problem, by that I mean I screwed up. Not knowing what I was doing I tried to press the bearing housing for the Z axis off the shaft, and it broke.
So now I get to make a new one on the lathe.
Glad to hear you are making progress, bummer that you broke the bearing housing. At least you have the means to make a new one.
Mill is looking good! I did the same exact thing to a bearing boss on my Lagun. It was a pretty thick/beefy part and it spalled off a couple of chunks. There was enough meat that I was able to fill the voids with TIG braze aluminum-bronze and re-machine.
