- Jul 17, 2017
- 71
So not only do I have to re-learn vertical milling after a few decades off, the sight-unseen mill came with about 200 pounds of various Kwik Switch stuff. I searched and found a few posts on here and learned a bit already. Thanks to you guys for sharing your experience.
The mill and the tooling had the kind of surface rust that mostly comes from neglect... Might have been left in an unheated humid shop, or possibly rained on a few times and then stored under cover.
This first pic is about 90% of them.
My method is to grab an old SS pan from the wife's stash and make it my own when she is not looking, and then pour a bit of bulk WD40 in it as a rinse agent.
This is about the worst of the collet type holders for rust.
After massaging some WD40 into the nooks and crannies and a bit of rubbing on the rust I stand them up in the corner of the WD40 pan to drain a bit, then they get wrapped in newspaper to sit for a few days.
Later I will get back in there and repeat the massage process before I get serious about it and use some fine abrasive or a wire wheel. Maybe that's a bad idea so that's why I am posting this so one of you Kwik Switch experts can grab me by the nape of the neck before I make a big blunder. (Well, I already made the big blunder of buying a mill unseen and none of you guys stopped me in time.)
I have heard that there are machinists who HATE WD40 (I even know a few.) I love the stuff, probably because I am an ignorant cuss. I have used it for everything from a rust loosener, penetrant, cutting fluid, bug killer to fishing lure dip (in the old days.)
Are there reasons not to use it as I have on these Kwik Shift tool holders?
