I don't think so but I will look, this topic has come up before, I have the original owners manual and it doesn't say in there either. I know mine has oil as I have checked it, and it weeps when I run it, but I too would like to know so I can change it. My Little burke works well for what I use it for, I still have not used it in horizontal, I usually just use the vertical attachment and the 3c collets with end mills. I like the little burke though, it is solid.Greg,
Nice find. I was wondering if the motor on your unit has a oil type tag still intact. I have the same mill and the letters on my oil ID tag got washed out when I cleaned up the machine.
Thanks, Al.
And I couldn't stop playing with the mill so I had to give the change over to the vertical attachment a try. It was really quite easy, I cave it a wirl under power and she is very smooth and quiet even at the highest speed.
What she looks like with the vert attachment installed.
You can also see the collet arbor laying on the table.
The vert assembly can be mounted on either side of the bracket that the top column goes through, that would give a larger range than I thought it would have,
Here you can see the number graduations are quite clear and the head is in great shape.
I wonder if I can mount an electric power feed to this table instead of the original pto drive unit? I think the p.o. did this at one time, I can't figure out any other reason why he would have removed it. I think he then transfered it to the rong fu mill my friend purchased. My thinking of doing this is all the motor power would go to the cutter shaft and not the table feed.
I've never been to the villiage, I can't seem to get out of the museum, it just fascinates me.
My first DECENT mill was a Burke#4. It was a real machine,capable of taking decent cuts out of steel. My table was a bit convex,which comes from years of tightening down stuff in the T slot. I had to have it re cut on the top,AND bottom,and the dovetail also. They did some more or less decorative scraping on the table,which was nice.
I can't tell if yours was re cut,since the rest of the machine looks so nice. I WISHED forever that I could have found a vertical head for mine,but never did. Did you see the slotting attachment another guy found?
