Boring wood on a Mill...?
When not using the CA glue, refridgerate it. Lases a lot longer.
"Billy G"
Another trick, grind an inexpensive spade bit down to the size you need, it's easy to do and can be made to bore a precise diameter. You can also grind down the diameter of a Forstner bit.
The Trepanning cutterJohnG mentions will work great if you only have a couple of holes to do. You can also use an adjustable spade bit though that are kind of pricey. In all cases use a drill press, a spoil board below is always necessary, sometimes one above is a a good idea as well, if you need an absolutely clean hole.
CA cures with water moisture. Dry storage is a must, although it can be recovered if hardened, just add acetone.
