- Dec 30, 2021
- 60
I have the Sherline DRO on both my lathe and my mill.
Sherline recently began selling a new chip for the DRO display. It allows the user to switch between inch and mm values on the display. I expect that I will probably buy the new chip for my mill, being that I plan to make some devices using metric plans and metric stock.
Two things that I don't like about the DRO are the poor visibility of the reference marks for the handwheels, and the handwheels not being resettable on the lathe -- for precision work.
A feature that I would like to have in a display unit is something to help with calculating and maintaining a feed rate in inch per spindle revolution. Not having such a feature, I calculate the required handwheel rotations per second at my intended spindle RPM. On my lathe, I have been using a metronome application on a smartphone to help with making the feed rate more constant as I turn the z-axis handwheel.
Using a metronome to coach your feed speed is a really cool idea.
