- Dec 30, 2021
- 60
I need to create a 14.5mm (~.591) hole in the end of some aluminum.
I have a drill that's a bit less than 1/2" with a reduced shank that I can get into the chuck of my lathe and make a hole.
I don't have a bigger drill and wouldn't think that one would necessarily help; at a certain point my little lathe is going to run out of oomph. So, I'm expecting to finish the hole by boring it.
I bought a basic 1/4" HSS tool set from Amazon which has a boring tool, but it's too large to fit into the hole that my largest drill can make. It appears that the Sherline boring tools will work with the hole that I have, but the few references to them I have seen in this forum are not very positive.
To be fair, those references were in the context of the milling machine not the lathe, so they may be OK for my purposes.
Ultimately, I'd like to reach the point where I can grind my own tools, but I'm very new to machining and am trying to concentrate on specific skills. Is there a boring tool that works with the Sherline lathe that folks would be comfortable recommending?
