- Apr 12, 2013
- 562
I am trying out a new borescope and need help understanding what I am seeing vs what is realistic to expect in the bore of a new barrel blank. If you paid for a midrange ($250-300) manufacturer's hand lapped barrel blank would you expect to find occasional reamer marks still present? How much is too much? Also, one of the tops of the rifling lands is frosty for about 4" near the muzzle, like it was a bit short and didn't get lapped.
Also, when turned between centers it has .009" of bow from high to low in the center of the barrel. Normal or unacceptable? #2 contour, so fairly thin but not featherweight.
I will add that this is my second barrel from this maker and the first shoots about 1.25 MOA and has similar bore finish. I don't want to spend the time to thread and chamber this one if it is also going to be similarly average. My first barrel was a Green Mountain unturned blank and while the bore is less 'clean' I turned it to a light varmint contour and it registers near zero deflection in the middle when turned between centers, and it shoots about MOA for a third the price.
Frosty land next to lapped one
