I use the angled end of the holder unless I'm threading, gives clearance on entry into the bore. That said, you're correct. Grind a left hand tool, but account for the angle of the tool, and give it a lot of clearance on the underside. For that clearance I grind as much away as comfortable for cutting tip support.
Hey Outsider, I see you have a Walker-Turner. Me too, although mine's been modified. I replaced the spindle with an ER16 spindle for milling. May be sacrilege to some, but I can put it back to original if I want.
