sort of the boat I am in? If I were to purchase over again, I would likely go for separate machines. I bought the machine because I came into a few thousand bucks a little while back and was asked to do something fun with it (long story) ... Anyway, It has mostly sat unused. I have done a few things around here and there, but mostly it has not been used.
...That being said, one of the things that has prevented me from using the milling part of it has been the fact that I mostly want to do small things with it, which requires me to lift the vise closer to the work. That has been my project for the last day or so. I cut an old trailer hitch into two pieces, roughly 2.5 inches long. The other two dimensions are both roughly 2" ... From there, I figured I would face them so their measurements are both identical. I have yet to finish with the first piece. For some reason, and this is very consistent, the piece ends up being about .004" taller on one end. I can't figure out why. I do know that when I lift on the milling table, I can feel and see a little movement that seems to be independent of the main body of the machine. It is hard to tell, but it seems like the whole milling table assembly moves together. All the gibs are tight... I have tried it with the vise mounted to different ends as well as the middle of the table, and it always comes out the same. Not sure what to do!
