- Apr 4, 2013
- 884
Bruce,You may try adding one to the number of holes. On my DRO, if I say a 0 - 360 pattern with 4 holes the holes will be at 0, 120, 240 and back to 360. Or actually a 3-hole pattern. If I enter 5 for the number of holes with a start at 0 and an end at 360, it gives the desired spacing of 0, 90, 180, 270 and the last one back to 360.
Bruce
You don't need to do this with TouchDRO. When you select 4 holes, it creates 4 distinct holes. In your example, it would be 0,90,180, and 250 degrees. That is, unless you explicitly set both angles, starting and ending. Then the DRO will place the first hole at the starting angle, last hole at the ending angle, and the other two spaced equally in between.
Regards
Yuriy
