Your math is correct, but I'm not sure of your physics. Any knowledge I had of Hooke's law is gone but the name. If the physics works, then do you really need max pressure? Or is max pressure the design limit, and the spring should be spec'd at a lower pressure. 72 psi will move a lot of lube through a very small orifice.
