- Sep 29, 2014
- 2,102
The chuck run out will be less then the error inherent in easily obtained cold rolled steel or brass and aluminum extruded hex shaped materials, if you require a higher degree of precision you will have to source material from elsewhere or mill/grind it yourself. If the hex portion is simply a wrench surface high precision is not required.
