Best Way To Hold Hex Stock In Lathe
mrjbinok
Apr 23, 2016
99
I'm sure that this has been covered elsewhere in this or another forum but I'm not finding it, I apologize.
I am considering a project that would start with a hex stock to make a tool that would resemble a regular bolt. My requirements are no way close to any standard bolt dimensions so I am considering hex stock.
My question is "What is the best way to center hex stock on a manual lathe and hold it for turning?" I'll be working with a 1" round after turning the body and I do not currently have any collet's near that size. Any suggestions?
Do you have a three (or 6) jaw chuck?
Or, you could turn the threads and make the flats for the bolt head on a mill.
Daryl
MN
I hold it in a 3 jaw chuck. Indicate off the lowest point on each flat.
I would think turning round stock would be easier and then just going to the mill and putting it in a collet chuck. that's what we did for our project.
I guess I forgot to engage my brain on this one. I do have a 3 jaw that has pretty good run out. For some reason I couldn't picture using it with the hex stock. I'm about 3 projects away from starting on this project, so I'm just kicking ideas around in my head while I work on something else. I am currently rebuilding a small Johnson Gas Forge and converting it from NG to LPG. I plan to use it for heat treating some of the pieces I make.
I won't be turning any threads on this, as it will actually end up being a two pin spanner to fit down into a recessed fork tube for old Harleys. Total length will be about 1 1/2". Right now I don't have access to a mill, so making do with what I have. I have a couple of different ideas on how I could get to what I need with the least amount of work.
Thanks for the input.
Jim
How about taking a piece of tubing with an I.d. a tight fit to the hex stock. Slit the tubing axially, press it on the hex stock, hold it in the 3 jaw.
Of course only slit one side.
David
Sent from my SM-G530T using Tapatalk
This guy uses a 4 jaw... I've never tried it. At about 7:30 in the video
If you haven't watched his video on the 1 micron lathe he built you should. It's incredible.
Of course a three jaw will work. I am embarrassed for "over thinking".
David
