I need to drill a few 1/4" dia holes in some 1/4" thick wall tubing.
The example hole is from the factory(yes the layup/material is different).
How do you suspect they made such clean holes?
I've read CF is very hard on drill bits and dulls them fast. The material is abrasive?
What type of cutting tool options are there that will work better then a twist bit? I'm not opposed to using a twist bit if it will cleanly do the job.
![IMG_4282.jpeg IMG_4282.jpeg](https://www.hobby-machinist.com/data/attachments/452/452599-c5fbe58923b88b794818839d48465497.jpg)
![IMG_4280.jpeg IMG_4280.jpeg](https://www.hobby-machinist.com/data/attachments/452/452600-2f3672ddc3e1cb281d197229e66f1924.jpg)
