- Oct 8, 2014
- 127
Not a lot of useful instruction that I saw in there. Specs, part names & locations mostly. Still a good reference when a guy needs it though.
Stock belt on my machine is a B-25, had to swap to the slower speed pulleys last night & it was a real *****. Motor case hits one of the headstock adjustment bolts. Belt is just plain tight too. Ordered a replacement from NAPA, (seeing the rubber dust already), but may end up going with a 26" instead.
Ran a test cut on a nice fat aluminum bar & the diameter was off around .004 in 6 or 7 inches. Running a dial indicator down the length confirmed the problem. Loosened the headstock bolts just a smidge & half the runout went away (indicated). Took the rest out with one of the adjustment bolts & did another cut. Ended up around .00025 that time so figure it's good enough for me. Haven't got around to the tailstock yet, had to tend to a wiring job in the house.
Curious whether the oil tends to have a foam on top in anybody else's sight glass? Will be draining & replacing it soon, so may be a non-issue anyway.
