My lathe (a European Atlas 618 copy) is powered by an old (50+ years) single-phase PSC AC motor. 370W, 0.5 HP, ~1400 rpm.
It works fine and provides enough power for what I've been doing so far.
However, the inrush current is huge. It causes a lot of noise on the AC line, to the point that other devices on the same breaker are affected.
Also, the wiring is old, the switch is not properly mounted in anything and insulated with ducttape, and it's not properly grounded.
All these things make the electrical engineer in me a bit itchy, so I'm looking to improve matters.
Rewiring the switch, mounting it in a proper housing, together with an emergency kill switch I can do.
But I'm looking at improving the startup spike problems as well, as I'd like the CD player to keep working when I turn the lathe on.
So far, I've been looking a couple of options:
- There is an ample supply of simple three-wire soft-start modules for table saws available on the interwebs. I have no idea if that would work if I wired one into the primary winding of the motor. At the price they're going for, I could just try it, but I can't find anything on how they work. If they limit voltage, they might cause an increased current that could damage the motor.
- Alternatively I could spend a bit more on an inrush current limiter. That would probably work a bit better, but also not sure on the compatibility with an old motor like this.
- I've been looking at 1-phase VFDs as well, but putting a multimeter on my motor, it looks like the primary and secondary windings are not identical, so I'm not sure how it will like being run as a 'real' 2-phase motor, without the capacitor in line with the secondary.
- The last option is simply replacing the motor completely, possibly with a DC model. That would probably make the whole thing a lot quieter as well, but is obviously the most expensive option. And in this category, there's of course the choice between a relatively cheap chinese motor, or going straight for something from a known brand (what are known brands in the DC-motor business? Not really my area of expertise).
So my question: Do you guys have any thoughts on which option would probably be best? Does anyone have experience with those soft-starters and/or inrush limiters? Are DC motors really better? Will any of this make me a better machinist?
