- Dec 20, 2012
- 9,422
I have a Jet 5X6 and it is an excellent saw out of the box. All I had to do was tune it and it has never gone out of adjustment once I set it. I haven't used a HF saw but understand that it requires some work, sometimes a lot of work, to get it running well.
I suggest joining the Yahoo 4X6 bandsaw group for some much-needed info on how to get these saws running well. The major issues with all of these saws are the flimsy table used in vertical cutting and the lack of a chip brush, both easily fixed by most HSM's; the info to do these projects are on that forum. Regardless of make, you will need to tune it up and the best guide to do this is also on that site, as far as I know.
I like Lenox bi-metal 10-14 tooth blades the best. Combined with a chip brush, it has cut without issues in all sorts of metals, including 0-1 steel, for over 3 years now without a blade change or a chipped tooth. Of course, this varies with usage but in a home shop I have had the best luck with Lenox. Starrett blades are okay, too. The OEM blade that comes with any of these saws is junk and won't last long; best advice is to not even install it and go with the bi-metal.
For all metals, but especially harder steels like tool steels and semi-hardened steels, you need a lubricant. Lots of folks use a wet system but its messy. I prefer a stick wax lube that really helps to speed the cut and leaves no mess. With a chip brush installed and was lube on the blade the material stays cool and cuts clean.
The only other shortcoming with these smaller saws is the lack of a hydraulic downfeed, which can be fixed by either buying or making a cylinder and valving. I don't use one and don't miss it in my home shop but if you cut a lot of material every day then it would be a consideration.
