- Apr 23, 2018
- 7,196
Beryllium and Hydrochloric acid (HCL) reacts, Copper and Hydrochloric acid do not react. A few drops of HCL on the suspect metal should tell you the story. If you get a reaction (bubbles, etching, etc), then it may have Beryllium alloyed with the copper. Do this test outside, and away from where creatures (including you) are.
If you have a Known piece of brass nearby, perform the same test on it and compare the reaction. The piece with beryllium will have a stronger reaction.
Brasses are alloyed with zinc, which also reacts with HCl, as does aluminum. The acid test might not be ideal unless you have a near-pure specimen.
