Boy, you guys can't even tell when I'm joking (admittedly not often enough). Just get a 1" 60 grit flapwheel in an air motor. About 2 minutes work.
This is an aluminum jack which was bent during shipping. The jack handle installs in this barrel. The barrel is non-ferruous so I assume it is aluminum. I didn't see it until I tried to install the handle.
what about milling a light flat on the handle to make it fit? might be easier to "fix" the handle than it would to really fix the tube...
just saying...
