- Oct 18, 2016
- 2,872
I wouldn't recommend a slow speed grinder for high speed steel. Wood workers (myself included) deal with high carbon steel hand chisels and hand plane blades. They won't tolerate heat, high speed steel doesn't care. HSS can get red hot and not affect the hardness, thats why we use it.
Just about any 1/2 HP 3400 rpm grinder will work, 6 inch wheels are fine but 7 or 8 are faster cutting as the surface speed is higher. A little hollow grind from the radius of the wheel aids in honing the final edge on a hand stone.
If you get an import grinder throw the stones away, they are little more than circular concrete disks. Get good quality ones. The white aluminum oxide ones are indispensable in the wood working shop, they cut cool but at a price, they fragment to stay sharpe and as a result wear fast, you don't need them for HSS.
Greg
Greg, I'm glad you clarified high speed vs. low speed grinders for me, as well as your comments on stones. You guys are giving me a great education on grinders, which was EXACTLY what I was
looking for when I posted this thread.
