- Apr 22, 2016
- 988
The main grinder with rigid table is done for the most part. Except for substituting a few metal sizes that I had on hand for ones that I didn't, it is built to plans. Still want to build a few accessories for it and paint it. When it is all done, I'll give a review of the plans and the build, with pictures of course.
For now, I have a question. I came across a 3-phase motor which is what I was hoping for in the 1st place. There is not a data plate on it and no markings whatsoever. It is totally enclosed but not fan cooled. The frame is cast, and the shaft does not protrude through the back. The shaft size is 7/8". It has a front-end mount (no base plate). There was a wire hookup diagram in the cover, and it had previously been wired for low voltage. I checked the wire numbers and hooked it to the Bridgeport VFD to test it and it works well.
This morning I wired a new VFD and programmed it before trying the grinder. It seems to work fine. The VFD had been set to 3 amps (default). Then I set the VFD display to read out amps and with normal grinding was drawing about .7 amps. When I pushed a large piece of steel against the belt, the amps increased to about 4.5 before stopping with an error. I know I can make an adjustment to the current value, but it would be nice to know the motor specs at least close.
My question--Is there a way to find out something more about this motor? my best guess is that is 2 HP.
Thanks
Aaron
Thanks
Aaron
