Beginner's Exercises & Projects
Not much of a project(s), but in my defense I'm still in the VERY early learning stages so "baby steps" for now...but having a blast leaning as I go!
I am a huge airgun enthusiast (reason for getting a lathe in the first place), so the following pics may not make much sense to some of you, but thought I would post anyways.
Rear-cocking hammer assembly for 2260 HPA (High Pressure Air). I didn't make the threaded piece...it's actually a brake line fitting that happened to fit perfectly.
Power adjuster for another rifle (first attempt at threading)
One of my first "mini projects"...I'm an archery buff too, so made up some inserts for a bunch of arrows.
Good morning, I was wondering if any experienced( or know anything at this point for me,,LOL) machinists ( close in location) would ever have a machining class to show beginners some hands on how to do and become familiar with some of the machines used( lathe and milling machine)..on another web sight for welding some guys do it a few times each year, its both a learning and meet and greet day...
I would advise this to those with no experience and who want to enjoy the hobby of machining:
1. Find the machine of your choice, have a machinist friend look it over. Then buy it if it's a good deal. Likely, you will overpay for it but you must start somewhere.
2. Start with simple cuts, using scrap material. Practice!...Practice!...Practice! Nothing beats experience.
3. A lot of information can be retrieved from web sites like Hobby-Machinist, Practical Machinist, etc.
I've never had any formal training with machining. I learned from default in my industrial maintenance career of 30+ years. If I can do it...anyone can do it
I am following steps 2 and 3. Simple cuts aren't so simple sometimes, especially to a novice. I look forward to the challenges that are in my future and plan to figure a way to struggle through them. In the mean time, I will look for some simple projects to improve (start) my skills.
Parting Off
I was working on my race bike one afternoon and had to do my cam timing. Sadly I used this raggedy setup for a few years.
Just a few nuts stacked up.
Well now I have a lathe, I decided it was about time I used it. One of the skills that really intimidated me was parting off stock. I had not done it and so it was time to learn. I read some posts on this site and got too it.
I took some aluminum stock and using the parting tool learned how to make a good part and how to control that part when it was cut off.
View attachment 79353View attachment 79354
So after a few tries I made simple stepped spacer and washer, used a rod in the tail stock to control the parts. I ended up with a small but useful little tool to go in my timing kit. But more importantly learned a good skill and gained confidence.
View attachment 79355View attachment 79356
I might add that this web site is one of the most useful tools I have.
Mark
The nut stack, I have done that before. Also stacked washers up too.
The chuck key on my recently acquired Atlas lathe was stripped and would barely work. My first "real" machining project was to make a pair of chuck keys. First of all, it feels great to make my own product. I learned a lot during this project. The key is a hexagon shape and I did my best with a magnetic angle finder to locate a 60 degree angle to make the teeth. I am sure it is off a bit but they are functional.
A good place to get material for your beginner project (or regular project) is a local steel supplier outlet if you have one near by. They have shorts and cut off along with long stock that they sell by the pound. My local place has mild steel (they don't know the type), aluminum and stainless in round, flat, plate and shapes. If your like me, my own car repair projects can provide your raw material. Shock struts, cv shafts and the like can provide some good raw material.
Also a side note, when I made the ball end to the handle by eye/hand, a few days later I found out there is such a thing as a ball-turning attachment for the lathe!
...Doug
Hey Doug, gravers would work a treat for ball turning on your little lathe.
