- Mar 26, 2018
- 2,725
One question on that DIY 4 way tool post that came with the lathe, are they meant to accommodate all the various sizes of tool bits?
So, yes... BUT you will have to shim them to get the tool height correct, which is a PITA in my opinion. An entry level quick change tool post will run you ~$100 but might be my favorite investment for the lathe. The toolposts increase in size (OXA -> AXA -> BXA... etc.) You're probably somewhere in the OXA or AXA range (measure your compound slide to spindle centerline height thats what matters). Check out Shars and CDCO tool. They have holders for any kind of lathe tool you can think of (including boring bars), and only take seconds to swap tools.
Inserts come in shape and size (the stuff that matters anyways), you tool holder will fit any insert with the correct shape and size. For example a 1/2" SCLCR turning tool holder will hold ANY CCxx 3x.xx insert (ones for steel, aluminum, different radii, etc.). In addition, that same insert might also fit your boring bar, chamfer tool, facing tool, etc.
Grinding HSS isn't hard, and is certainly worthwhile to learn. I keep plenty of HSS tool bits on hand. Those books listed above are great.
I agree on the buy/make of the boring bar. Steel shank inserted ones aren't expensive ($20-30), and brazed carbide 9 piece sets will get you a great place to start for even cheaper, but you mileage may vary one the quality of those tools.
