Beefing up my 9x20
They are a bit of a pain to use. But our instructor has beat into our head " calipers are for roughing, mics are for precision." An let me tell you this puppy is nuts tight. This was an area where I wanted tight. Most what I have done calipers would do fine
Moving along.
After the two bottom bores were done we flipped the work. Turned the face down to a decent shoulder then camphored it. Then we drilled the 4 mounting holes and milled off the corners. Then we did a little trig to find my angle for a degree ring viewing slot. I wanted it angled so you did not have to squat so much to see it. I had to do 24* because I had no way to set the minutes and seconds. It worked out perfect.
10155333_829056727109288_4033692547574281479_n.jpg1509033_829056787109282_7043813042119851648_n.jpg1978897_829056700442624_5911246178230164632_n.jpg10305520_829997340348560_5223028032410149167_n.jpg
- - - Updated - - -
few more
10155333_829056727109288_4033692547574281479_n.jpg 1509033_829056787109282_7043813042119851648_n.jpg 1978897_829056700442624_5911246178230164632_n.jpg 10305520_829997340348560_5223028032410149167_n.jpg 10256102_829997370348557_5053441627652409209_n.jpg 10298910_829997403681887_8216806724901727630_n.jpg 10154925_829997420348552_8438928002917984453_n.jpg 10171860_829997440348550_7353751637987466145_n.jpg 10330260_829997517015209_6697888526116178809_n.jpg
Then we milled a .085 recess in the bottom of the cross slide. The idea was to mill the bottom of the nut to fit the recess but have a larger lip for support. I failed to check to see if my drawing would fit the machine other then the cross slide. So in a pinch I turned the BP head to 45 and got it right. I drilled and tapped the top for a 1/4-20 and the nut it's self to a 7/16-20LH.
10253814_831806753500952_1681793992799010702_n.jpg1621849_831806720167622_9208870680534283485_n.jpg1508991_831806696834291_1120161084068958818_n.jpg1511342_831806630167631_2901586771323571984_n.jpg10171860_831806500167644_914705761134849554_n.jpg
- - - Updated - - -
few more
10320403_831806466834314_7225597792790674745_n.jpg10269505_831806410167653_4503536731491493919_n.jpg1901192_831806300167664_1881450805268143580_n.jpg10277457_831806540167640_8742083137086352971_n.jpg1972551_831805980167696_2832609686797781616_n.jpg10172744_831806010167693_2729158446746579681_n.jpg10259319_831805866834374_907827389253475679_n.jpg10322789_831805820167712_7291414426435772744_n.jpg1900034_831805793501048_1594672634753327270_n.jpg
10253814_831806753500952_1681793992799010702_n.jpg 1621849_831806720167622_9208870680534283485_n.jpg 1508991_831806696834291_1120161084068958818_n.jpg 1511342_831806630167631_2901586771323571984_n.jpg 10171860_831806500167644_914705761134849554_n.jpg 10320403_831806466834314_7225597792790674745_n.jpg 10269505_831806410167653_4503536731491493919_n.jpg 1901192_831806300167664_1881450805268143580_n.jpg 10277457_831806540167640_8742083137086352971_n.jpg 1972551_831805980167696_2832609686797781616_n.jpg 10172744_831806010167693_2729158446746579681_n.jpg 10259319_831805866834374_907827389253475679_n.jpg 10322789_831805820167712_7291414426435772744_n.jpg 1900034_831805793501048_1594672634753327270_n.jpg
What material is that lead nut made from? Mine is Bronze and has been in use for two years now with no ill effects.
"Billy G"
It's alum. I intend to make one from bronze with a turned nub to fit the oem hole. But my cast one is broke in half so I cant turn anything till I have a nut.
Good on ya. Aluminum would not hold the thread tolerance long with a steel lead screw. The back pressure during even a moderate cut would soon end up in more problems like Backlash. I have to strip the cross-slide on mine today. I will post a picture of mine.
"Billy G"
The turned nub is called a "Spigot".
Plain Jane. No need for anything else. I also did away with the Grub Screw that Jet had on it. It only cocks the nut causing more wear.
"Billy G"
That would be great. I went with alum just for that reason. For a temporary solution I would just assume it leave no wear on the permanent parts. I had steel, alum, or cast iron so I just picked the softest.
Plus I learned alot through minor error. The next one will be much easier and cleaner I'd say. I would like to have machined the side angles as more then an after thought. I drew out the part and made it to the drawing. But in my hast I neglected to check the clearance on the carriage. My intent was a 1.0 x 0.9 nut. .9 is a .125 per side to much.
These cheap machines are expensive school books. Long as I'm learning
- - - Updated - - -
Thanks Bill. I assumed that screw just screwed into the screw. My oem nut must have been broke in that area as the screw had nothing over it but the screw. The nut was in front of it. So thats how I made mine
