On all beds for Atlas metal working lathes. whether the swing is 6", 9", 10" or 12", the entire top surface of the front and the rear ways is, before use, finish ground to all be in the same plane. However, neitherthe headstock, saddle or tailstock are supported by the entire width of either way. This is usually quite obvious on a used bed as usually you can clearly see where the saddle and the tailstock have been running. And a narrow strip running from headstock to near the right end of the bed shows where nothing has been running. So setting a precision level of adequate sensitivity across the bed and comparing the readings at both ends will give you the amount of twist in the bed for the unworn portion only. To indicate twist in the regions where the saddle actually runs, you really need to shim the level up more than the way wear front and rear (which is unlikely to be the same). However, as a practical matter, unless the bed is really badly worn, you are probably just trying to split hairs if you worry about that. The original accuracy of the lathe was only claimed to be +/- 0.001". Moving the decimal point one place to the right could be expected to move the decimal point in the dollar cost of the machine a like amount. To quote a well-known author of yester-year, TANSTAAFL.
