OK -- I'll try the "bit of cloth" trick if it turns out to be necessary.
But going back to the "clamp between pieces of aluminum" thing... when I'm drilling, do I use the light thin lubricant for aluminum (I'll be going through 1/2" of that) or the oily lubricant used for stainless?
Also: I'm hoping to make a disk-shaped part in this thin stainless, with a few holes drilled in the middle of it. About 3.25" diameter. I think I can manage the holes and slots in the middle, but making the piece "disk shaped" in the end is what's worrying me. If I were doing this in wood, I'd use something like a trammel cutter. Is there a similar tool I can use on thin stainless clamped between two sheets of 1/4 aluminum? I'm not using a CNC machine, so just milling it won't work. I could bandsaw it, with the two pieces clamped together, but it'd be tough to get a really nice circle. It doesn't have to be perfect, but my bandsaw skills are...limited, and it seems as if a milling machine is perfectly set up to help me do something circular like this.
