According to the article on your lathe--it has a 1"x16tpi spindle thread on the head spindle and the same on the tail spindle--the tail spindle has an internal mt1 taper. It said the headstock spindle was 9/16" bore and had a steep taper for unknown collet. *did you get any collets with your lathe or a drawbar to pull the collets in? also did you get a 1"x16tpi threaded collet nose piece? your lathe sure looks nice in the pictures. if you can get a manual on your lathe it should have all the information you need--maybe some of the members have a model like yours that can help you figure everything out. --Dave
