The 4x6 in vertical mode is still not a vertical bandsaw.
The small horizontal one I got from Harbor Freight does stand up and comes with an about 8X8 inch platform that can be temporally bolted on to stand up and use as a hand feed vertical band saw. So some do have that capability. It would be nice to have a full time vertical one though.
This might sound crazy but is there any reason you couldn't use one of the crappy import rotary tables (less than $50) as a speed reducer? could you use one in place of a gearbox as JimDawson did?
Here is what I did to my Horrible Freight 14" bandsaw to cut metal. It works amazingly well!
http://rvbprecision.com/garage-ente...c-drive-wood-to-metal-cutting-conversion.html
This is a Harbor Freight 14" saw that I cut wood with for years before finally replacing it with an old 20" Powermatic that I found a good deal on. It is a 1725 RPM motor directly driving (a 1-1 ratio) a 30-1 reduction gear box that I got at surpluscenter.com for under $100 and another (roughly) 2-1 reduction in the final drive. It gives me a blade speed of about 80ish feet per minute. I may change the lower pulley to speed it up a little. I was originally afraid that the final belt drive might slip, but it has not been a problem.
