- Jun 27, 2019
- 109
Does the loss of coolant result from the stock not being level or maybe oddly shaped stock?We have a 7x12 Horizontal / Vertical bandsaw and a DeWalt 872 cold saw (that replaced one of those awful abrasive cutoff saws - ugh!).
90% of our cuts are done on the cold saw. It's fast and does a respectable job cutting stuff that will be processed further or welded as-is.
The bandsaw is nice when used in horizontal arrangement because you can set it up and do repetitive cuts without babysitting it. And the cuts are cleaner but when you use the coolant system it flows along the stock and piddles on the floor
I had a power hacksaw long long ago but it is very slow going.
If I could have only one saw it would be the cold saw - small footprint, fast cutting, relatively good, clean accurate cuts. JMHO
Stu
I don't see this issue in mine.
I have a 7x12 and also a metal cutting miter saw and a 14" metal cutting chop saw (not cold saws, just carbide blades run at low speeds). The carbide saws are very fast but they do waste a bit more stock than the band saw and are very loud.
